Results 1 to 2 of 2
Thread: LML Stock Files
    Jan 2011
    Default LML Stock Files
    I am doing a harness and engine swap for a customer, we will be using a LGH - 6L90 from a 2011 van. Can i use any OS that matches the ECM or does it need to be from a van? van os as per TIS is 12646249, I have a few truck OS's that are the same. I assume that the engine would be at truck power levels.
    Or do i need to buy a file for the vin?
    Aug 2008
    If you use the truck vin for the ecm tune then it would be at a higher power level than using a van os. Ecm and tcm are separate so you shouldn
  1. Replies: 8
    Last Post: April 20th, 2016, 11:24 PM
  2. LML Files
    By Coletrain45 in forum Duramax 2011+ LML / LGH
    Last Post: July 8th, 2015, 03:16 AM
