Results 1 to 2 of 2
Thread: Trying to change vin on E80 ECU. Having issues
    May 2018
    Default Trying to change vin on E80 ECU. Having issues
    I connect an E80 ecu and change the vin with 7.5 Scan tool. If I do not clear codes before writing, I get error out of range. If I do clear codes before writing it will act as if it's going to write but then the vin will be the same original after turning the unit off for 15 seconds.
    Any help here?
    The Clear DTC before changing VIN is a requirement on the E80 (well, on many late model GM ECM's).
    Are you doing it in a car or on a bench harness?
    If you are doing it on a bench harness it must be wired up so that when the Ignition 12V is turned off the Battery 12V remains, it is during that shutdown period the ECM will actually writes the VIN.
  1. VIN change
    By zittman in forum Cummins 5.9L
    Last Post: April 16th, 2019, 02:06 AM
  2. VIN Change
    By D_Met in forum Gen III V8 Specific
    Last Post: September 24th, 2018, 11:34 AM
  3. E80 L4 SIDI how is boost increased what tables to change? 2016 camaro 2.0 turbo.
    By david imgrund in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 12th, 2017, 12:11 PM
  4. VIN Change
    By chrleb2 in forum Cummins 5.9L
    Last Post: June 16th, 2011, 10:38 PM
  5. vin change
    By 69camaro5speed in forum Vortec V6/V8 Specific
    Last Post: January 24th, 2007, 12:08 AM
