Results 1 to 1 of 1
Thread: V7.5 scan tool DVT theft relearn process
    New Member Turbosaurus's Avatar
    May 2015
    Default V7.5 scan tool DVT theft relearn process
    Does anyone know the correct procedure for using the theft relearn feature of V7.5 scan tool DVT on an E38 ECM? I've been trying the cycle method of relearn (3 cycles/600 seconds start-on), but failed to clear “Service Theft Deterrent System".
    Attempted to use DVT function Anti Theft Relearn though I could not find any documentation on the procedure. Selected Activate and Relearn. Nothing happened immediately, so cycled ignition off/on and “Service Theft Deterrent System” DIC message disappears and security indicator lamp goes out. Attempted to start but still would not crank. Attempted the cycle method of relearn (3 cycles/600 seconds start-on). Deactivated the DVT function. “Service Theft Deterrent System” immediately shows on DIC along with security indicator lamp.
    Seems like it wants to work, but the engine won't crank and it doesn't stay cleared. Any suggestions?
  1. Anti Theft Relearn using Scan DVT on E38
    By Turbosaurus in forum E37, E38 & E67 PFI ECM's
    Last Post: May 6th, 2020, 01:10 AM
  2. Scan tool DVT procedure for VATS relearn
    By Turbosaurus in forum Gen IV V8 Specific
    Last Post: April 28th, 2020, 01:03 AM
  3. Replies: 1
    Last Post: September 10th, 2019, 09:51 PM
  4. Scan Tool DVT ECM Setup CASE
    By hapnermw in forum General
    Last Post: September 7th, 2013, 08:56 PM
  5. Replies: 19
    Last Post: May 18th, 2011, 12:38 AM
