Results 1 to 4 of 4
Thread: BEN selected from LTFT or WB is showing up as not valid
    Nov 2009
    Default BEN selected from LTFT or WB is showing up as not valid
    Last time I updated EFI Live I lost all my files and setup. I also changed computers.
    I am not using a MAF this time. I am following the tutorial included in the sticky and copied and pasted the user config file.The BEN from LTFT and BEN from WB show up individually.
    I have a 2000 firebird. The OS was updated to the slightly newer style operating system (forgot the name) and I am using a custom operating system.
    Any idea as to what I should check?
    Thanks,
    Bill
    Did you verify the PIDs?
    Al
    Nov 2009
    Actually I had forgotten about validating PIDS so I tried but unfortunately it didn't work.
    Thanks for the suggestion.
    Nov 2009
    Never mind. I didn't have the calc.cl pid but still had cal.pe pid (tutorial was updated). I forgot you could right click on the pid and it provides a reason as to why it's not valid. Thanks
  1. Replies: 30
    Last Post: April 8th, 2017, 10:59 AM
  2. Replies: 5
    Last Post: October 1st, 2012, 12:42 PM
  3. What's messing with my AutoVE? BEN and LTFT counters.
    By shadowskill in forum Gen III V8 Specific
    Last Post: October 16th, 2010, 09:33 PM
  4. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
  5. Valid & non valid pids
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2006, 10:22 AM
