Under the CM2350B user guide it says under each CSP5 file there should be a parameter box for A9134. This would allow you to have that tune only run off of the min/max in that tune file and not the four alternate files. Was this removed? Will the tune still only run off of the min/max in that tune file? I notice in the files you only have one min/max and in previous model PCM and ECM there were two under each tune file.
