Results 1 to 10 of 10
Thread: CME Limited at 20 Degrees of timing.
    Aug 2019
    Default CME Limited at 20 Degrees of timing.
    Hey everyone. I am working on my performance tune on the CME platform. I have seem to hit a timing limiter. I know in some of the old model ECM there was a limiter table, but not in this one. Any help on how to get around it? Would reducing the pilot timing in the internal flash allow for more main timing? Thanks for the help.
    Oct 2012
    There's an actual limiter calibration that is set to 20 crank degrees.
    Aug 2019
    I couldn't find this limiter like I could on my 07.5. Is there a table number it is under?
    Quote Originally Posted by RD TRCTR View Post
    I wasn't aware of that, thanks for the tip. Sounds like we better add that in.
    Aug 2019
    That would be awesome. Trying to keep my fueling in a 50/50 split and not possible with that limiter stopping me at 20 degrees.
    Aug 2019
    GMPX do you know when the timing limiter table will be added. I have customers trucks to do but cant finish without this limiter removed.
    What OS are you working with?
    Aug 2019
    CME OS-32140602 and Cal ID. 32370231SB
    It has an internal limiters of 20 degrees of timing.
    Try this .calz, just save it into:
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\CME
    The two new parameters are under the 'Main Timing' folder.
    Aug 2019
    You ROCK! Thank you so much.
  1. 60 degrees commanded ignition timing
    By PSI in forum Gen III V8 Specific
    Last Post: February 26th, 2018, 11:41 AM
  2. 0/-2 degrees timing on cammed 2006 GTO
    By Brad Kimbler in forum Gen IV V8 Specific
    Last Post: March 4th, 2017, 01:36 AM
  3. LMM Timing/fuel Limited?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 9th, 2014, 06:54 AM
  4. Idling at -5 degrees timing=$ thrown away
    By killerbee in forum Duramax LLY
    Last Post: August 12th, 2009, 01:58 PM
  5. 4 degrees timing retard needed
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2006, 01:42 AM
