Results 1 to 10 of 13
Thread: Stupid user - need autocal explained
    Jan 2020
    Default Stupid user - need autocal explained
    Hi all, could someone please take time to explain some EFI live autocal basics to an admittedly ignorant user. I have an autocal that came with a delete kit and I installed the tune with the deletes. Ran great. Got the unlock code and had another tuner custom tune for some modifications. Runs great.
    Can I put the old tune file on the device and use the old tune by flashing to the truck? Will I need another unlock code ? If I do this can I keep the new tune? How do I do this on my laptop...I do have the software downloaded.
    2017 Cummins 2500
    Apr 2011
    Load Tune into the AutoCal from an Email
    Download and Install EFI Live V8
    From there open up EFI Live V8 Scan and Tune , Plug in AutoCal to USB , Check the Firmware and Updates
    Save the BBX file to your Computer
    Navigate to the BBX file and double click ,it will open in EFI Live Scan and Tune
    Click Program Quick Setup to copy the files to the Autocal
    Once completed you can unplug the Autocal and go out to the truck.
    Load Tune into Truck from the AutoCal
    Unplug the CSP5 Switch
    Plug in AutoCal and turn Key on
    Scroll down to Full 2
    Click Ok
    Checking
    Erasing wait
    Flashing %
    Wait for the Flash to complete
    When completed turn off the Key and hit Ok
    Countdown will Start
    Unplug
    Sent from my SM-A505W using Tapatalk
    Jan 2020
    So I can save each file to my computer and save whichever one I want to the autocal whenever I want to change tunes ?
    Apr 2011
    Yes
    Jan 2020
    Great. I appreciate the help
    Apr 2011
    Anytime the power level is changed we recommend that you do the drive learn...*
    Simply put 30 or so miles of STOP and GO driving at very*light*throttle*will normally be enough for this to happen on a stock*transmission.*
    Jan 2020
    I have a revmax valve body, bd converter, doe pan and case brace. I also have a snap on scan tool and can do the learn procedure on the trans...
    Apr 2011
    No, not a*"relearn"*(a relearn is done with a scan*tool*and resets the adapts to factory standard) but rather a drive learn
    You might have to ask Revmax
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Double post
    Jun 2011
    summitbound This is only true if the same tuner wrote both tunes. This doesn't seem to be the case here. It appears The OP has unlinked his autocal from the original tuner and to to one who wrote the custome tune. If this is the case you cannot use the original tune unless you relink the autocal to the original tuners flashscan.
    To the OP. You can only flash tunes from a single tuner with an autocal device. You can use as many tunes from that tuner you like. No other tuners files will work and fail to flash. The autocal device is linked to a tuners flashscan so therefore the tunes saved with that flashscan are the only tunes that will work with the Autocal. Think of the autocal as a slave device of a master flashscan.
    If you want to flash files from multiple tuners then you need a flashscan device.
    Sent from my SM-G960U using Tapatalk
  1. CVN's Explained.
    By GMPX in forum Tips and tricks
    Last Post: December 6th, 2021, 12:00 PM
  2. LMM Programming History & CVN's Explained
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 8th, 2010, 09:10 AM
  3. Windows Vista Explained
    By Chevy366 in forum Lounge
    Last Post: September 23rd, 2007, 04:42 AM
  4. Probably a stupid ?...
    By Loudmouth LS1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2007, 03:39 PM
  5. Power enrichment mode explained...Please:)
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2006, 07:09 AM
