Results 1 to 3 of 3
Thread: CME2350B injector is during regen?
    Aug 2019
    Default CME2350B injector us during regen?
    While data logging I noticed when letting off the throttle or at idle during regen it showed 5,000us. Is this normal? Boggled my mind that it would say 5,000us. Also said 5 degrees of timing. Amy help on this would be great. I am worried something is not right with the the base file because no where in the tune file should it ever go to that duration.
    Oct 2012
    Yes, 5000 microseconds during regen is typical.
    Regen calibration is not included in EFILive.
    Aug 2019
    Thank you so much! I thought it had to do with the regen but was not sure. Now I can rest easy lol.
  1. Service Regen
    By hacklerjason in forum Diesel
    Last Post: July 21st, 2016, 06:21 AM
  2. Cummins regen?
    By fjcruiser in forum Diesel
    Last Post: May 16th, 2016, 07:17 AM
  3. Regen Tables
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 7th, 2013, 03:20 PM
  4. how to tell if regen is on
    By ods dan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2008, 01:51 AM
