Results 1 to 2 of 2
Thread: 4.3 CPI tuning valve and secondary injectors
    May 2020
    Default 4.3 CPI tuning valve and secondary injectors
    I have a 4.3 CPI that I am re pinning to a 0411 from a 01 blazer. Its being converted to a manual, I found a base tune file to work off of.
    1st Im wondering if anyone has any experience adding input and outputs to the 0411. At 3k RPM I want this tuning valve to open. Its either open or shut and uses 12 volts to operate.
    2nd in all the tunes I am finding that use a manual, why does the transmission calibration have parameters of any kind? When looking into a manual tune file you still see TCC and downshift, upshift parameters.
    To add an output, the PCM circuit board must have a driver (power transistor/fet) to sink the current... so you would have to see if you have any unused driver and if you can address it.
    See the response to you other thread regarding MT vs AT.
  1. Tuning with new injectors (12613411)
    By redtacoma31 in forum Gen III V8 Specific
    Last Post: December 11th, 2017, 11:26 AM
  2. Help tuning with larger injectors
    By RonnieW in forum Gen III V8 Specific
    Last Post: May 11th, 2017, 05:59 AM
  3. help tuning injectors
    By pdasterly in forum Gen III V8 Specific
    Last Post: June 14th, 2015, 12:51 PM
  4. Tuning new injectors
    By braapp in forum Gen III V8 Specific
    Last Post: January 7th, 2014, 10:36 AM
  5. Tuning Bigger Injectors Help
    By BrianC98Z28 in forum Gen III V8 Specific
    Last Post: February 10th, 2008, 03:40 AM
Tags for this Thread
