I'm using the LM-1 outputs to monitor my AFR through EFILive. From my experience with datalogging this signal appears "noisey." I am wonder if the "noisey" reading is normal and I need to apply a filter or if there is something maybe I over looked with my setup. I have tried applying the data filters but the console signal for the wideband varies 0.8-1.5 volts per frame at 100 ms per frame. I've gone through the wiring tutorials and manuals and I'm pretty confident it is wired correctly. Any help or comments would be greatly appreciated. Below is data I have logged with the data filter on with the setting "exclude data frames" enabled and with the condition to exclude any frames that change more than 1 afr per frame.
