Results 1 to 3 of 3
Thread: CME PIDs injector balance rates
    Nov 2010
    Default CME PIDs injector balance rates
    I am having an issue with a rough idle on a CME 2014 truck and was going to attempt to look at injector balance rates, however I can not find it in the pids.
    Nov 2010
    No one has any input on this?
    Oct 2012
    Quote Originally Posted by tidony View Post
    Injector balance rates are not able to be "scanned" with EFILive. You're best off to use a SnapOn Solus Edge.
    The issue you're experiencing is probably cold start. Record Main Injection time, RPM, rail pressure and torque. You will probably see a "noisy rpm signal" and will notice that your main injection on time is about 400 microseconds higher than is shown in the main injection on time table.
  1. LB7 injector balance rates
    By minytrker in forum Duramax LB7
    Last Post: August 24th, 2014, 02:51 PM
  2. Injector balance rates what # makes you worry?
    By RyeThomas in forum Cummins 5.9L
    Last Post: August 13th, 2012, 08:44 PM
  3. injector balance rates
    By Hunter t in forum Diesel
    Last Post: June 11th, 2012, 12:38 PM
  4. How to scan/check injector balance rates?
    By duramax07tmd in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 7th, 2011, 02:50 PM
  5. LB7 Fuel Injector balance rates reading 0
    By StuntHeavy in forum Duramax LB7
    Last Post: July 7th, 2010, 02:03 PM
