Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: struggling newbie needs direction
  1. #11
    Member jeeper's Avatar
    Oct 2018
    Can someone confirm the log I took has the info I need? I have a short log made and I need to learn how to proceed. So far most of my effort has been in trying to get this far I haven't started reading what to do next. I'm just trying to verify that where I'm at is where I should be so far.
    2002 Duramax
    project Jeep Wrangler to CJ conversion with a LS engine and 6L80e transmission underway
  2. #12
    Oct 2018
    I decided I'd better make another log. This time I used an old tablet computer. Is this better?
    2002 Duramax
  3. #13
    Aug 2016
    Your last log is close. If you open it and click on the data tab, you can see your minimum, maximum, and average values for each PID. There should be data for the CALC.VET, CALC.LTFTBEN, and CALC.SELBEN PIDs but they stay at 1, 0, or N/A for the whole log.
    I clicked on the PIDs tab, it looks like CALC.SELBEN has a red x. Right clicking and choosing More Info shows that you need to log the CALC.WO2BEN PID as well. Make sure you have that PID selected, do a short log, then stop the log and take a look at the data tab to make sure you're getting data for each PID you have selected.
  4. #14
    Oct 2018
    I'm not really sure why but on my computer screen I see two lines for CALC.VET and one line is populated. Same for CALC.VEN. Just curious if you used my calc_pids.txt file to view the log or doesn't that matter?
    Here is what my log looks like on my screen.
    Curious why mine shows data?
    Also I went ahead and completed the steps in the tutorial and came upe with this. I don't plan to try running it. It doesn't look right to me.
    Is it normal to have the scan software need to replot the log file everytime it opens?
    Edit:
    I see why there are two lines each for those. One is percent and one is g*K/kPa.
    2002 Duramax
  5. #15
    Aug 2016
    I might have seen incorrect data if I'm missing your wideband PIDs.
    It looks like you're really close. Make sure the units from your logged correction map are the same as your tune's VE table. I highly recommend keeping everything in metric units and using the VE units, not percent.
    Your first VE update looks like you copied percent values into a table with VE units. Notice that the maximum allowed value in your VE table is 10.0, and the peaks are at that maximum.
    Sent from my Pixel 3 using Tapatalk
  6. #16
    Aug 2016
    Also yes, when you open a log everything will need to update. Same when you apply a filter.
  7. #17
    Oct 2018
    How do I verify what my logged units are?
    2002 Duramax
  8. #18
    Aug 2016
    Edit your map in the scan tool. The first tab for data should let you choose a PID and it's units. Check there, make sure it is g*K/kPa.
  9. #19
    Oct 2018
    It looks like they match but I'm probably missing something?
    2002 Duramax
  10. #20
    Oct 2018
    I'm curious if maybe my results are indicating I have a vacuum leak somewhere? I've already checked for one because I suspected one earlier in the process but I didn't fine one. I'm going to test for a vacuum leak again and this time try to be more deliberate.
    I just ran through the process again of calc.vet but got the same results. If I continue to try the same thing over again expecting different results I think there's a word for that...
    The thing is, the engine is running the best it's ran since I started this whole process and I haven't even made a proper tune yet.
    With LTFT and closed loop disabled the Jeep is very drivable. It is a tad rich at idle but at cruise speed it is sometimes staying right around 14 AFR on my wideband.
    2002 Duramax
  1. E39A Struggling for power?
    By Buzzer in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2016, 04:20 PM
  2. New to Tuning, Struggling with VE adjustments
    By rbp4u in forum E37, E38 & E67 PFI ECM's
    Last Post: June 4th, 2015, 12:51 PM
  3. Requesting guidance in direction of minor tune (newbie)
    By sonicgroove in forum Gen III V8 Specific
    Last Post: January 31st, 2013, 09:24 PM
  4. Newbie looking for direction
    By rizaptor in forum Duramax LB7
    Last Post: June 9th, 2012, 01:56 AM
