Results 1 to 9 of 9
Thread: Dealer warranty
    Aug 2019
    Default Dealer warranty
    Does anyone know if the dealerships can verify a truck has been tuned with EFILive and void a Custer's warrant? There seems to be a lot of yes and no out there. I have a customer asking with a new 2019.
    The ECM's have reflash counters if the dealer knows where to look. I don't know if their tools have the ability to show that.
    Aug 2019
    Where would they look for the counter? I have a Snap On Modus scanner. If I can see that, then they would also.
    Dec 2016
    I'm not familiar with these controllers but most times this is stored in nvram where reading and altering require "security" access.
    Aug 2019
    Thank you for that information I appreciate it.
    Quote Originally Posted by Twistedshafts View Post
    It is just a simple CAN message, so any scantool can see it if they know what to send. I don't know what tools Dodge use at the dealerships but I would be 99% sure they can see it.
Name:	CMF Reflash Counter.png
    Aug 2019
    Okay, I see now. That makes sense and since it is a brand new truck they should have record of how many flashes it has had. That could be a giveaway for them. Do the checksums have anything to do with it?
    Dec 2016
    Wrong forum and sorry for the sidetrack, do you happen to have the mode info for this in the e92?
    I'm not 100% sure because the ECM has several different checksum methods happening at once over different ranges of the ECM.
    But because the ECM is in total control of the flash process on the Dodge ECM it is probably the ECM that increments the counter given it knows it just got flashed.
    Re the E92 comment, at some point GM did stop relying on the CVN to log flashes, but we don't attempt to disguise that the ECM has been flashed so I've not kept up to speed on what they are doing now.
  1. OT - Ford Mustang Warranty
    By cindy@efilive in forum Lounge
    Last Post: April 29th, 2014, 09:15 AM
  2. Do I need to mail warranty card?
    By LM7Tuner in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2009, 10:54 AM
  3. Warranty return - EFILive Pen
    By jsttry in forum Lounge
    Last Post: April 17th, 2007, 01:16 PM
  4. Warranty is void
    By Blacky in forum Lounge
    Last Post: January 24th, 2006, 04:57 PM
