Results 1 to 10 of 10
Thread: Add Steering Wheel Controls?
    May 2020
    Default Add Steering Wheel Controls?
    I have a v2 for my ls swap project and would like to use it on my 'shop van', an 08 savana. It used to be a rental so it has the 75 mph speed limit and no cruise. I'm fairly confident I'll be able to raise/remove the limit but will it be able to activate cruise if I get a new steering wheel? I've read it needs to go to the dealer but I'd rather not. I have experience using HPT but am new to efiLive. I don't want to burn a credit if it won't be able to as I'm sure I'll be able to get speed limit + cruise at the dealer for approx the cost of a credit, but if I can I have no problem doing so just to remain self sufficient.
    Thanks!
    The cruise control system has to go through the BCM first. You can add the switches (buttons) on the steering wheel and replace the SIR (airbag) coil to transfer the connection to the under dash harness. I am not sure if the cruise will work but have seen it work in later model G vans. EFI_Live can handle the speed limiter.
    Al
    Nov 2005
    The dealer will NOT be able to add cruise control. GM has gotten very stingy in regards to adding features that werent originally on the vehicle
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Nov 2005
    I can do a custom BCM tune for you to enable cruise control...thats the only way.
    The custom BCM tune will also disable the rental speed limit.
    12.9s @ 108 mph
    May 2020
    What tools are required for that? Tech II or equivalent? I'm trying to stay local with it for now but I'll reach out otherwise. From my experience with HPT the speed limit is in the ecm so that's interesting.
    Hmm, chinese tech 2's are like $250...
    Nov 2005
    Quote Originally Posted by travisn View Post
    You cant do it with a tech 2.
    I sell custom BCM tunes in .ctz format that you can flash with your EFILive V2. The BCM uses a TCM license spot on your V2.
    Ben
    12.9s @ 108 mph
    Ben
    How is that going to work with EFI Live ditching the licensing of TCMs?
    Sent from my 2PZC5 using Tapatalk
    Nov 2005
    Actually im not really sure...Ross would have to answer that one...
    12.9s @ 108 mph
    May 2020
    Gotcha, I saw this during my search today: https://www.efilive.com/latest/news/bcm-flashing/
    Are you the Ben referenced there?
    Edit: I can't PM yet, could you shoot me a message? Thanks.
    May 2020
    @DURAtotheMAX
  1. 2017 Suburban e92 Cruise and power steering inop
    By Midwesttech in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 30th, 2019, 09:53 AM
  2. Low speed, full lock on steering, stalls!
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2009, 11:29 AM
  3. Corvette steering column ?
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2008, 02:51 PM
  4. Steering bogging/idle problems
    By Haans249 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2006, 04:46 PM
  5. Wheel sensors
    By Dark Angel in forum Tips and tricks
    Last Post: October 7th, 2005, 08:54 AM
