Results 1 to 4 of 4
Thread: T43 OS 24249179 2500HD 4WD Stock File Needed ASAP
    Sep 2018
    Default T43 OS 24249179 2500HD 4WD Stock File Needed ASAP
    I need pickup truck stock file for 24249179 OS ASAP. This is a customers vehicle. Thanks
    Sep 2018
    I read the calibration from the old tehcm and thought I could flash it to the reman unit I installed. The reman unit, however has the previous vehicles calibration still on it and because of an OS mismatch it wont flash. I get a U0100 code in the tcm, but the truck does run. I don't want to road test until I can resolve the issue. Will flashing a compatible OS file to it cure this?
    Jun 2008
    Here Ya go! sorry its really late, but someone else might need it
    T43.ctz
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    John, Thanks.
  1. Stock file needed; 2010 cts-v e67 + t43
    By SOMFormula in forum E37, E38 & E67 PFI ECM's
    Last Post: November 5th, 2019, 03:06 AM
  2. Need stock TCM files asap please / '11 Escalade 4wd
    By Boost in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 22nd, 2017, 07:49 AM
  3. HI STALL Upgrade 2,000RPM up to a 3,000RPM info needed ASAP please t43 GEARBOX 6L50e
    By 3L SIDI in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 21st, 2015, 03:24 AM
  4. Stock 2009 Corvette T43 .tun with the 24249179 os
    By whypave in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 25th, 2011, 02:14 PM
  5. Need Stock 2010 Camaro file ASAP
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: November 11th, 2009, 05:11 PM
