Results 1 to 2 of 2
Thread: 2013 3500 Ram 6.7 with Aisin trans unable to read file
    May 2017
    Default 2013 3500 Ram 6.7 with Aisin trans unable to read file
    Have a 2013 and when using V8 with my V2 it says it will auto detect a CME controller with a large red X over it and no trans, Try to read it says "Reading CME controllers is not supported in pass-through mode"
    Was told by another tuner that EFI live can not do this year with the Aisin trans.
    I only need someone to build me a custom tune for the engine, not looking for a bunch more power,
    Thanks, Jeff
    Nov 2005
    You cannot read any CME controller. The factory read restriction prevents reading 2010+ Cummins (CMD, CME and CMF) controllers. Users must obtain a base file to tune with.
    Please refer to this document for help on how to determine your stock file http://content.efilive.com/documents...ck%20Start.pdf
    You will find a range of stock files here https://forum.efilive.com/showthread...k-tune-library
    Cindy
  1. Replies: 1
    Last Post: May 19th, 2019, 09:09 AM
  2. 2017 ram 3500 cummins 6.7 p026a
    By Christian_GM in forum Diesel
    Last Post: May 17th, 2019, 04:26 PM
  3. 2011 ram 3500 ecm code
    By mopar-mechanic in forum Cummins 6.7L
    Last Post: December 18th, 2018, 11:25 AM
  4. 2012 Ram 3500 Stock tune 12351331AN Please?
    By crdth in forum Cummins 6.7L
    Last Post: April 15th, 2015, 01:57 PM
  5. Aisin trans file into 68RFE ECM?
    By LBZoom in forum Cummins 6.7L
    Last Post: August 23rd, 2014, 03:15 PM
