Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: June 2020, Beta Release - Release 4
    Is there any chance you could please Email one of the .tun files you had problems opening to support@efilive.com ? (or post it here if you don't mind it being public) I tried a few that I had here and they were ok.
    May 2014
    I just tried 5 different ones that I've been messing with.
    12212156 - OK
    12221588 - OK
    12593358 - Error
    12587603 - Error
    12592425 - Error
    In all cases, even with the error, it seems to work OK. If I save as a CTZ it opens without error.
    Screenshot and tune files attached
    Thanks, annoyingly they all opened up without error here . I'll try on a different PC and see how it goes.
    the ones i was having issues with were all custom os 1290005
    if i read the tune out with 7.5 i get error. can't save. read it out with v8. opens and edits fine.
    Dec 2012
    Your signature Josh, Tuned Aisin , well done.
    Thanks!
    On the CAX8 stuff... It seems like it requires a .CAM file for the file to even be recognized in the v8 editor even if there is a CAX8 file definition. There was some AL5 stuff I had were I just would disable the CALZ and populate everything from .cax to avoid all the conflict errors. Will this still be possible?
    Josh
    '04 GMC LLY
    I'm not sure Josh, I'll get Paul to respond but he is away sick at the moment so it might take a few days for him to get back to you.
    May 2014
    I have one small gripe/recommendation for EFLive Explorer.
    Everytime you open it, it defaults to F12: Firmware tab
    Wish it would still default to F3: Data Files
    Jul 2020
    I have a EFI Live V3 Autocal. I've downloaded EFI Scan and Tune Version 8. I tried to update the firmware. I keep getting an error $0020 "USB Driver DLL Not Loaded" Error. Can someone please tell me what I'm doing wrong?
  9. #19
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Running EFILive on a Mac using Parallels is not detecting the Flashscan V2 or Autocal V3. All versions up until this Beta have worked well.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
  10. #20
    EFILive now uses a special Microsoft ID string in the USB enumeration (so that it works carefree with Windows built in drivers) and for some reason that appears to be causing problems for Macs.
    A couple of customers have run into this but apparently it still works on some older Macs (indicating the issue sits with the Apple hardware and / or Parallels).
    Sorry to say but at this stage there is little EFILive can do to resolve this, we went to the updated drivers so it was easier for the 99% of customers who are using native Windows machines with EFILive.
  1. June 2020, Beta Release - Release 3
    By GMPX in forum Software Updates and Installation Help
    Last Post: June 25th, 2020, 06:15 PM
  2. June 2020, Beta Release
    Last Post: June 19th, 2020, 02:00 PM
  3. June 2020, Beta Release - Release 2
    Last Post: June 19th, 2020, 01:56 PM
  4. June 2016 Release Candidate 2
    Last Post: August 17th, 2016, 12:48 AM
  5. June 2016 Release Candidate 1
    Last Post: June 13th, 2016, 10:44 AM
