Results 1 to 3 of 3
Thread: Reed Switch / Hall Effect Input
    Oct 2010
    Default Reed Switch / Hall Effect Input
    Hi All.
    Looking to log some driveshaft rpm again the engine rpm data captured on canbus. Is there any easy way to bring in a two wire reed switch, or maybe a hall effect sensor on the V2 A/D inputs?
    Tks
    -K
    An A/D input measures voltage (eg 0V - 5V), not pulses like a hall effect sensor would produce.
    Although the V2 does have inputs to monitor switch states they are not sampled fast enough to be used for what you want.
    Oct 2010
    Thanks for the clarification. I saw a thread about converting pwm to 0-5v input. But was looking for a quick and dirty option. Time to look at the TCM options.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  1. Red Pin 53 TCS/ASR Timing Retard Input Enable Switch
    By LSxPwrdZ in forum Gen III V8 Specific
    Last Post: March 1st, 2013, 04:59 AM
  2. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
  3. Ported TB effect on VE?
    Last Post: April 22nd, 2008, 02:02 AM
  4. 12 volt switch input
    By XLR8NSS in forum External A/D inputs
    Last Post: November 22nd, 2007, 10:01 PM
  5. Tuning VE with RR...no effect
    By Wichita Dyno in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 6th, 2007, 05:18 AM
