Results 1 to 5 of 5
Thread: Timing Limiter CME OS-32140602 and Cal ID. 32370231SB
    Aug 2019
    Default Timing Limiter CME OS-32140602 and Cal ID. 32370231SB
    GMPX did the new software update incorporate the timing limiter in this OS? We have the issue of it stopping timing at 20 degrees.
    Yes, if the .calz dates are 27th May 2020 then the parameter is in there for all OS's (so just download the latest beta).
    Aug 2019
    Is it necassary to install the beta software on a different computer than the one I use for my customer tunes? Also do I actually have to buy another V2? Can the beta software harm the V2?
    Quote Originally Posted by Twistedshafts View Post
    We would recommend that while software is in beta simply due to the fact there can be version incompatibility between old releases and beta.
    For people just tuning their own vehicles and not needing support customers that might not be a concern.
    No.
    We hope not!
    Here's what you could do if you don't want to install that beta on your main PC.
    I've attached a zip to this post that contains those updated .calz files, you can extract that zip into the folder on your work computer:
    C:\Program Files (x86)\EFILive\V7.5\Calibrations\CME
    Then when you reopen your CME files you should see the .calz date showing as 27th May 2020 and you will have the max timing parameter.
    Aug 2019
    Awesome! Thank you I appreciate very much. I always back up my finished tunes on an external hard drive, but you never know what may happen while building a current tune.
  1. CME Limited at 20 Degrees of timing.
    By Twistedshafts in forum Cummins 6.7L
    Last Post: May 20th, 2020, 12:28 PM
  2. B3702 Injection timing normal ECT cal table data issue - EfiLive vs HPT
    Last Post: October 11th, 2019, 08:10 AM
  3. CAX and CMD, CME
    By Red66 in forum Cummins 6.7L
    Last Post: July 13th, 2017, 05:53 AM
  4. LMM timing limiter and pilot issue
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 4th, 2009, 03:48 PM
