Results 1 to 7 of 7
Thread: CM2100 C&C Supported OS
    Jul 2012
    Default CM2100 C&C Supported OS
    Hi, a remote customer provided me with a AutoCal read for a 2010 C&C with a 2009 CM2100 ECM. The O/S is 11710806 and I am assuming that this version is not supported for a CSP5 upgrade per the CSP5 docs, but I am not even seeing the ability to perform edits to the stock read. The Internal Flash is empty within V7.5. Does this mean that this O/S is completely unsupported?
    If so, what would a good safe Stock file be to use that would allow CSP5 upgrade for this truck? It is a C&C Manual trans.
    Many thanks for any help!
    2006 Ford F250 Super Duty, 2008 Cummins 6.7, Allison 1000 5spd
    2011 Ford F250 Super Duty, 6.7L Scorpion
    Jul 2012
    Any insight at all? I've read a bit about the bootloader version, but how can I update that?
    Amazingly we've never seen this OS before, you'd think all options would have been uncovered by now. There won't be a CSP5 conversion option for this OS but if you can send in the read to support@efilive.com I'll look and see about adding in support for it.
    Jul 2012
    Yeah that's just my luck. I will send it here soon...thanks!
    It might not get added same day, we are a little backed up at the moment.
    Jul 2012
    I understand
    Jul 2012
    Hi, just wanted to check in and see if you guys have had a chance to look into the mappings for this OS? I sent the read back on Jul 8 and I know you are super busy, but just wanted to check back. My customer has been hanging in there with me. ;-)
  1. 2008 cm2100 OH ding
    By WPDiesel in forum Diesel
    Last Post: May 30th, 2017, 07:26 AM
  2. E67 supported vehicles & Cal files (Updated 21-October-2008)
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 18th, 2010, 12:42 AM
  3. P12 supported vehicles & Cal files (Updated 20-Feb-2008)
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: February 12th, 2009, 11:13 PM
  4. E38 supported vehicles & Cal files (Updated 21-October-2008)
    Last Post: June 17th, 2007, 01:04 PM
