Results 1 to 3 of 3
Thread: 2005 LLY / AL5 Limp undet wot
    Jan 2011
    Default 2005 LLY / AL5 Limp undet wot
    Hello,
    I have tuned lots of 4l60/80's never really played with the AL5.
    I put a 100hp tune in a 2005 LLY against my advise into a customers service truck, a very heavy k3500.
    When he goes wot, the transmission goes into limp mode, Is there anything besides building a transmission that can be done?
    Put it back to stock..... Even then, since it's been limped, depending on how many times it's limped, putting it back to stock might not stop the limps. 100hp over is 'Walking the line' even with a fresh stock LLY/AL5. Some hold it, some don't. Anything with mileage is a huge roll of the dice.
    Sent from my 2PZC5 using Tapatalk
    Quote Originally Posted by derkscustomcars View Post
    Hello,
    In this truck, limp is almost always in 5th gear. Torque is what creates it. If you drop the tune 10-20 HP, and build an AL5 tune that prevents 5th gear below 2400 rpm (downshifts to 4th at higher speeds and lower throttle position), you can eliminate the limp. Or just advise the customer to get smarter with his right foot in 5th gear.
    Custom Tuning Services
  1. 2005 cadillac cts-v - limp mode on dyno
    By GR8GAME in forum Gen III V8 Specific
    Last Post: May 28th, 2018, 03:19 PM
  2. 2005 LLY No SRT's are enabled? Wont Pass SMOG California
    By blades11b in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 27th, 2017, 07:39 AM
  3. Manual trans os for a 2005 LLY
    By ShawnM in forum Duramax LLY
    Last Post: May 6th, 2012, 02:05 AM
  4. 2005 LLY DSP5 shifting question?
    By haulinit in forum Duramax LLY
    Last Post: May 2nd, 2012, 02:45 AM
  5. 2005 LLY Fuel mileage
    By dieknow in forum Duramax LLY
    Last Post: February 7th, 2006, 05:54 PM
