Two Stage Nitrous Dry/Wet
If I understand what I have read so far...
I can use the IAT for the Dry shot and make tables to pull timing for just the dry shot based on colder IAT.
For the Wet shot, set that up on the new OS so that when the Wet system is active, it will pull timing using the valet feature of the OS.
What happens if I do both the wet and at the same time? Will it use the IAT timing tables or the Valet ones (guessing valet ones)? Likely solution when using both systems together need a tune that pulls timing for both in the valet mode is likely the best thing to do???
