Results 1 to 9 of 9
Thread: Pid Error
    Aug 2016
    Default Pid Error
    I tried earlier to create a PID to show me AFR error comparing my wide band AFR to commanded AFR (E92.AFR_DMA). I figured the math was right since it's easy enough, but it came up with the attached error when I restarted SCAN. Not quite sure what it's telling me, any help would be appreciated.
Name:	EFI Live Error_1.png
    May 2014
    post your calc_pids
    Aug 2016
    Quote Originally Posted by aaronc7 View Post
    post your calc_pids
    PRN 031 is the problem one I think, if I get rid of it, no more error.
    May 2014
    I think the error message is telling you that the error is happening at Line 48.
    The numbers / equation etc should be in line 48, after the word "factor". The CLC-xxxxx line should be blank otherwise like all the other calculated PIDs.
    Give this one a go
    calc_pids.txt
    Aug 2016
    It looks like that did the job, I think. Just going to start a log right now, I'll let you know.
    Thank you
    Aug 2016
    Yup that did it. So you just moved the Low/High/Fmt/Exp down 1 line to line 48 then? Thank you so much for the help, now just 1 more little issue to tackle (hopefully) and I can get tuning.
    May 2014
    Quote Originally Posted by RC1 View Post
    No problem, just a lazy Sunday, lounging around, glad I could help!
    Yeah if you look at the format for all of the other PIDs... you have to define the min, max, precision and equation for each "unit"....in this case it unit is "factor". So yep, that's all I did, copy and paste data in line 47 down to line 48.
    Good job everyone
    Aug 2016
    Thanks again Aaron, here is the new successful calc_pids file.
  1. GM.GearCom PID causing error report
    By bubba68ss in forum General
    Last Post: February 9th, 2019, 06:57 AM
  2. filter references unselected PID error?
    By Gregs in forum General
    Last Post: August 9th, 2010, 07:27 AM
  3. error updating pid in bbl
    By nathans1987 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2010, 08:47 AM
  4. Error message after attempting to create new PID list
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: April 6th, 2008, 10:44 AM
