Results 1 to 9 of 9
Thread: 2001 LB7 says locked with key While trying to tune ecm
    Jun 2020
    Default 2001 LB7 says locked with key While trying to tune ecm
    I have tuned this truck many times with different tunes, after it sat for a while, while I was building the engine more, I tried to tune to a hotter tune, and a few other tunes and it says locked with key. I have never had this issue and the tune that is in the truck currently is definitely not locked with a custom key. I was able to re tune the trans but not the ecm. I also have a security light now that I can not figure out or find. I do have the trace file, but can not upload it via my phone apparently. This is my first post, so go easy on me
    Apr 2017
    Quote Originally Posted by Lymansc2 View Post
    Sounds like you possibly bricked your ECM. Did you pull the right fuses while tuning?
    LB7 ECM's are notorious for this, the corrupt and lock themselves!
    You may have to end up getting the ECM sent off to get restored back to how it was, where are you located?
    Jun 2020
    It sat for 8 months and hasn’t done anything but this since engine reinstall. I’ve pulled fuses while tuning and I have not, never had an issue. Truck still runs and drives
    Jun 2020
    I’m in Grand Rapids michigan
    Yes that is what they do, they sit for a while and then next time it is powered up the ECM is corrupted, just bizarre.
    I'll contact a person that should be able to get it restored for you that isn't too far away.
    Jun 2020
    That would be much appreciated
    Jun 2020
    Did you find anyone??
    Oh sorry, yes try - http://www.wait4meperformance.com/
    They are near you so turn around should be quick.
  1. Changing custom key value in "locked" E67 ECM
    By required field in forum E37, E38 & E67 PFI ECM's
    Last Post: March 4th, 2018, 06:15 AM
  2. PCM secured With a Custom Key (LOCKED)
    By Level2 in forum General
    Last Post: August 6th, 2017, 11:31 PM
  3. LS1B PCM locked with a custom key
    By 400ss in forum Gen III V8 Specific
    Last Post: April 24th, 2015, 03:02 PM
  4. Code $0537: Controller is locked with a custom key
    By 9mmkungfu in forum Duramax LB7
    Last Post: May 1st, 2014, 09:21 AM
  5. "controller locked with custom key" DEAD ECM
    By DURAtotheMAX in forum Duramax LLY
    Last Post: May 14th, 2012, 12:25 PM
