Results 1 to 6 of 6
Thread: Tables for E85
    Oct 2010
    Default Tables for E85
    I am looking to do basically a stock tune for E85 in my 2017 Camaro SS. I was told all the tables for e85 are populated and just have to turn the stuff on. My question is the AFR tables are all 14.11 so do i just leave it there and let the PE tables adjust for the e85 or do i need to put the afr tables to the proper afr? I ordered a kit for flex fuel so waiting on that.
    Oct 2010
    Nobody? I know you guys have done this before. There is a ton of info on hp tuners just wish this forum Would share more.
    Junior Member JuhaniLS1's Avatar
    Nov 2006
    Same,I think AFR table has to be adjusted to proper AFR with % of E85 mix. Thats I have too seen in HP.
    Camaro SS Hyper Blue EU -19
    Oct 2010
    Isn't that what the PE tables do though? Adjusting AFR is easy i know stoich for gas and for pure ethanol so should pe linear. Thats my understandingvis anyways that Pe adds fuel to get the proper afr needed so please correct me if i am wrong
    Mar 2014
    Default E85
    Here is what an E85 enabled calibration looks like:
ID:	23427   Click image for larger version.
    Nov 2006
    Yes thats how I also put AFR, sensor shows 53% alcohol mix, car works flawless. Should sensor diagnostic be set on and set SES incase sensor fails?
    I have not yet really used power as car has 1000miles only. To release more torq/power which tables should be tweaked.
  1. E85 conversion
    By shane in forum Gen III V8 Specific
    Last Post: September 8th, 2015, 03:12 AM
  2. E40 throttle pedal tables cruise tables
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: August 28th, 2014, 06:10 PM
  3. need help with e85 pid
    By Big Block in forum Gen III V8 Specific
    Last Post: March 3rd, 2013, 06:22 AM
  4. EFI LIVE Tables vs HPT Tables
    By TIM Z in forum General
    Last Post: January 18th, 2011, 09:42 PM
  5. E85 Os???
    Last Post: July 3rd, 2007, 02:15 AM
