Thanks to Blacky for letting us show our wares here at the lounge.
I started to dabble in making custom panels, I really enjoy doing the graphics on these panels, and laying them out...Pretty much mostly C-5 Corvette stuff, working on a full length C-5 panel next, but here are some panels I have done, and are readily availiable. Just remove the ashtray, no cutting of the dash console needed whatsoever.
Three Switch Panel
Four Switch with an opener
Three Switch with a digital gauge
The Digital gauge can be EGT, Boost, Nitrous Pressure, Fuel Pressure (These are the DynoTune guages, red or Blue backlighting see their site for what they got).
Here is the one I am using on my dual Stage system.
The Line Lock switch is through the factory lighter hole, just used laminate on each side of the console with a 1/2" hole. The dash console is uncut.
I can do custom panels up to 12" high x 18" wide.
Email me or PM through the board if your interested in one. If its flat and can be made in laserable laminate, I can probably do it (Square switch cutouts or round does not matter). The laminate I use is 1/8" thick so it does not flex like a standard laminate material does when you hit a switch.
Beer
