Results 1 to 6 of 6
Thread: Scan setup
    Oct 2010
    Default Scan setup
    Wonder if some of you can help a brotha out. Want to start tuning my 2017 camaro SS and wonder if you guys had a good setup for pids or can send me a whole dashboard. Eventually i plan on installing my LC1 wideband sensor, unless the camaro has wide bands?
    Try logging these pids:
    GM.AIRPERSEC
    GM.ETCTP
    GM.EXHCAM1DC
    GM.INJPWB1
    GM.INJPWB2
    GM.INTCAM1DC
    GM.KNKRET
    GM.KR
    SAE.ECT
    SAE.FUELSYS
    SAE.IAT
    SAE.LAMBDA
    SAE.LONGFT1
    SAE.LONGFT2
    SAE.MAF
    SAE.MAP
    SAE.RPM
    SAE.SHRTFT1
    SAE.SHRTFT2
    SAE.SPARKADV
    SAE.VSS
    EXT.WO2AFR1
    EXT.WO2EQR1
    EXT.WO2LAM1
    EXT.WO2ST1
    Oct 2010
    Sweet ill give it a shot. I have been outta the gas game awhile i have alot to catch up on. Are there tutorials that work on the E92?
    Oct 2010
    Cool they all works i have some questions though.
    1. The lambda where does it get that info from cause other than when i first started the car it stayed at 1.011 for my whole 50 mile trip to work.
    2. KR and KNKRET are they the same things?
    3.what is ETCPT?
    4. The inj pulses whats the difference between the 2?
    Aug 2016
    SAE.LAMBDA on an E92 is actually the Commanded EQ Ratio, which probably explains the constant 1.011.
    The 2 INJPW pids are for Bank 1 and Bank 2.
    ETCTP is ETC Indicated Throttle Position.
    SAE.LAMBDA may be commanded EQR or commanded Lambda (i.e. 1/EQR)... you have to look at the logged waveform to make sure (i.e. during PE EQR should go above 1.00, and Lambda should go below 1.00).
    KR and KNKRET are slightly different (and sometimes one does not work)... choose the one the produces the higher values.
    +1 on the other pids as said by RC1.
  1. Replies: 2
    Last Post: June 2nd, 2017, 03:34 PM
  2. Replies: 6
    Last Post: December 24th, 2016, 06:15 AM
  3. Scan Tool DVT ECM Setup CASE
    By hapnermw in forum General
    Last Post: September 7th, 2013, 07:56 PM
  4. Replies: 8
    Last Post: June 17th, 2010, 06:50 PM
  5. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 02:41 AM
