Page 14 of 14 FirstFirst ... 4121314
Results 131 to 137 of 137
Thread: Fuel Pressure input
  1. #131
    Nov 2006
    "A" is black (ground)
    "B" is gray (5v reference from the gauge to sender)
    "C" is purple (return signal from sender to gauge)
  2. #132
    Nov 2006
    *UNITS
    #Code System Abbr Description
    PSI Imperial PSI "Pounds Per Square Inch"
    # Add slot definitions here
    *CLC-00-001
    PSI 0.00 100.00 .2 "({EXT.AD1}*25)-12.5"
    CALC.FP F001 CLC-00-001 PSI Fuel "Fuel Pressure"
    if 0v=0psi and 5v=100psi
    should`nt it be {EXT.AD1}*20)?
    i ask because with no voltage it shows -12.5psi.
  3. #133
    Nov 2006
    Quote Originally Posted by mr.prick
    *UNITS
    *CLC-00-001
    am i wrong?
  4. #134
    I thought 0.5V=0psi and 4.5V=100psi.
  5. #135
    Quote Originally Posted by TAQuickness
    well I'll be a post whore...
    In this post you attached a Schematic of the EGR
    Any chance you know where i could get one for a 05 LLY Duramax diesel?
    I found one for the ECM but its not showing the wire colors and I also have a fluke but i dont seem to be getting any 5 volt power from and of my EGR wires
    I have un plugged the EGR plug from the motor and Im checking each pin with no luck?
    Any help would be apreciated
    Thanks Simon
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
  6. #136
    Jan 2005
    This is what my manual has for an '05 LLY EGR pin out. Click the pic for a larger, readable, version.
  7. #137
    TA you are the best, Thanks so much!
    Duramax power
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. vx ss fuel pressure????
    By HINDZY in forum Gen III V8 Specific
    Last Post: October 12th, 2007, 02:27 PM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Boost pressure input and logging
    By diynoob in forum External A/D inputs
    Last Post: March 4th, 2007, 02:08 AM
