*UNITS
#Code System Abbr Description
PSI Imperial PSI "Pounds Per Square Inch"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
PSI 0.00 100.00 .2 "({EXT.AD1}*25)-12.5"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.FP F001 CLC-00-001 PSI Fuel "Fuel Pressure"
if 0v=0psi and 5v=100psi
should`nt it be {EXT.AD1}*20)?
i ask because with no voltage it shows -12.5psi.
In this post you attached a Schematic of the EGROriginally Posted by TAQuickness
Any chance you know where i could get one for a 05 LLY Duramax diesel?
I found one for the ECM but its not showing the wire colors and I also have a fluke but i dont seem to be getting any 5 volt power from and of my EGR wires
I have un plugged the EGR plug from the motor and Im checking each pin with no luck?
Any help would be apreciated
Thanks Simon
2017 Trailblazer 2.5L Dmax
07 LBZ rc lb EFI - Sold
05 lly cc lb, EFI 80hp tune-Sold
01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
Duramax power
TA you are the best, Thanks so much!
Duramax power
