Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 137
Thread: Fuel Pressure input
  1. #11
    Quote Originally Posted by Beer99C5
    From the Dynotune instructions...
    Please read the LC-1 controller handbook cover to cover so you understand the principles of operation.
    1) Connect your laptops program cable to the “IN” connector on the LC-1.
    That's incorrect, see section 5.3 in the Innovate LC-1 manual
    (it says to connect the terminator plug into the "IN" connector):
    http://www.innovatemotorsports.com/s...C-1_Manual.pdf
  2. #12
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Waiting on the harness...
    I think this is where I should be looking...
    What I hope to do is use the Wideband AFR 2 (AFR_LC12) and edit the sae_generic.txt file to something like this?
    V 0.5 4.8 .1 "{EXT.AD2}"
    AFR 0.0 100.0 .1 "{EXT.AD2}*10"
    *CLC-00-931
    factor 0.0 2.0 .1 "{CALC.AFR_LM12.AFR}/{GM.AFR}"
    On the LC-1 I agree to log to Logworks2 you need to connect to the out line.
    I beleive to program the LC-1 you must connect to the In Line...
    Innovate gave me a RMA, so hopefully it will work when I get it back.
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
  3. #13
    Jan 2005
    Just checked the front porch... Summit is fast. Got the sender, wire harness, and they threw in a hat and catalog. Not too shabby.
    As for the wiring, I suppose the red is +12, black is ground, and purple is the signal? Also, Beer, where did you get your fittings?
  4. #14
    Jul 2006
    Ahh man, you got a free hat? My harness is coming from Autometer, the sending unit I got from Summit (they forgot my hat though )
    Yes purple is the signal.
    The fittings I got from Summit, -4 swivel is the blue one, then a -4 to a 1/8NPT
    LOL you'll have it working before me..tag you do the tutorial
    Maine USA
  5. #15
    Jan 2005
    If I have to order fittings, I bet you beat me to it. I think I might be able to dig some up at work.
    The hat is nice too.
  6. #16
    Jul 2006
    Got the harness, made a spreadsheet to compare the autometer Volts to FP (since I will not be running a gauge.
    http://www.retrorelics.net/jim/Board...terFPgauge.xls
    Should be messing with it today...
    Maine USA
  7. #17
    Jan 2005
    I've had 0 luck finding the fitting's locally.
    Nice spreadsheet. Where did you get the 0.5 - 4.5 vdc? I was under the impression the transducer was 0-5 vdc.
  8. #18
    Jul 2006
    From an Email from their tech support.
    Hello.
    That sender operates based on a 5v input, a chassis ground, and a
    return signal based on pressure. 0.5v = 0 psi, and 4.5v = 100 psi. This
    is a linear signal.
    You may purchase a harness through our Service Department at
    815-899-0801. The cost is $25.00.
    Thank you.
    Cory
    Tech/Service
    Maine USA
  9. #19
    Jan 2005
    I need some coffee... Thanks for posting that again.
  10. #20
    Jul 2006
    LOL ok I have it all in...what do I do now?
    Am I on the right track with changing one of the wideband's file to reflect the above Voltage/pressures?
    V 0.5 4.5 .1 "{EXT.AD2}"
    PSI 0.0 100.0 .1 "{EXT.AD2}"
    *CLC-00-951
    Not sure what this does...
    factor 0.0 2.0 .1
    TA hit me up on Yahoo mess.if ya can
    Maine USA
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. vx ss fuel pressure????
    By HINDZY in forum Gen III V8 Specific
    Last Post: October 12th, 2007, 02:27 PM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. Boost pressure input and logging
    By diynoob in forum External A/D inputs
    Last Post: March 4th, 2007, 02:08 AM
