Results 1 to 3 of 3
Thread: SAE.MAP Issue
    Aug 2016
    Default SAE.MAP Issue
    I've got something really simple that seems to be kicking my butt here. At some point in the last few days my MAP readings have gone all crazy. I'm using the 12592525 GM 3 Bar, Linear/Offset settings are 312.00/-11.25 as always, and my minimum/maximum are set the same. I've checked the 5V supply to the sensor and it is good at 5.0V, and the Signal voltage shows at 1.7-1.8V. In Scan Data instead of seeing 100kpa I'm seeing 32kpa, which corresponds to the 1.8V Signal V if I were using a 1 Bar sensor. When I start the car, it goes to 0kpa, which of course messes with the Map/Baro Ratio. I've already installed a new spare Map sensor with the same results.
    Somewhere along the line something has gone awry, but I'm not sure where to go next. Any help would be appreciated.
    Aug 2016
    Ok well it took looking back at a post from 7 years ago, but somehow the units for B2101 got changed from kpa to PSI! We're good for now, thank you.
    Ok, good you got it sorted out
  1. Sae.map
    By izaks in forum General
    Last Post: July 2nd, 2020, 10:04 AM
  2. What is the deference between {GM.MANVAC} and {SAE.MAP}?
    By odd boy in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2008, 06:37 AM
  3. GM.MANVAC vs. SAE.MAP
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2007, 04:32 AM
  4. Main VE doesn't match MAP.SAE
    By LSs1Power in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2007, 03:11 PM
  5. Why doesn't SAE.MAP not work? (2-bar)
    By Alvin in forum Custom Operating Systems
    Last Post: October 27th, 2006, 06:07 PM
