Results 1 to 2 of 2
Thread: 2008 Ram 2500 with a download not accepted code $0340
    May 2017
    Default 2008 Ram 2500 with a download not accepted code $0340
    2008 CMC and Get's all the way to the end of download and says "Script exited with code $0340: Download not accepted ($40)."
    Any Ideas ? Thanks in advance!
    Sounds like the ECM might still have the anti-tuning protection enabled. Depending on what version of software you are using depends how it can be disabled, the method below works for all versions.
    There is two .ctz files you can use to disable it (if that is the problem).
    Under 'C:\Users\YourName\Documents\EFILive\V8\Tune\CMC'
    CM2100A_BootRSA_Patch_Auto.ctz
    CM2100A_BootRSA_Patch_Manual.ctz
    Flash the matching one in, then after doing that you should be able to flash in the modified file.
  1. 2020 brazilian ram 2500
    By romulo_sampaio in forum Cummins 6.7L
    Last Post: January 9th, 2020, 09:59 AM
  2. looking for base tune 2013 ram 2500 6.7 manual.
    By TZapoluch in forum Cummins 6.7L
    Last Post: September 16th, 2019, 11:46 AM
  3. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 01:47 AM
  4. 2008 with error code 0340.
    By Curt in forum Cummins 6.7L
    Last Post: December 18th, 2016, 10:15 AM
  5. RAM 2500 Cummins CM2200 U1601 DTC
    By cashbonus in forum Cummins 6.7L
    Last Post: September 15th, 2016, 08:19 AM
