Results 11 to 20 of 25
Thread: P59 COS3 04073003 flex fuel issues
    May 2014
    The cax file is basically defining several more tables that are present in the PCM, but were not ever defined by EFI Live back in the day when they worked on it.
    You'll find most of the new tables under Fuel->Flex Fuel, but also a few in Spark->General and Fuel->crank/start
    Mar 2009
    okay so basically i put that file in C:\Program Files (x86)\EFILive\V7.5\Calibrations then open my tune as normal and compare to the tahoe ff? is that correct?
    May 2014
    Correct
    Mar 2009
    Mar 2009
    so basically this .cax file allows you to compare dissimilar os's that are the same base?
    May 2014
    No you've always been able to compare base OS against the COS versions of that OS. The cax just defined some more flex fuel tables, ones that you need to change to make flex fuel work. Open up the cax file in notepad and you can see what tables were added.
    Mar 2009
    Huh well i learn something new everyday. I did look thru the cax file in notepad its kind of like adding a custom pid sort of i guess in a way i was just so completely lost. I really appriciate your time sir and i will do my best to share what ive learned. Thank you.
    Mar 2009
    Nailed it man thank you so much!!!!!!
  9. #19
    May 2014
    no problem, you can look at commanded AFR to make sure it's changing with ethanol content as well. If you want to add spark with ethanol there's a few tables for that in the spark section as well.
  10. #20
    Mar 2009
    yeah my plan is to leave boost where it is and increase power with timing while checking plugs for the time being. ill log timing tomorrow and see what its doing to make sure im not to advanced
  1. P59 Flex Fuel OS with DBW
    By LabZ in forum Gen III V8 Specific
    Last Post: January 29th, 2019, 04:36 PM
  2. Truck won't start with cos3. Runs fine with regular file. 12587603/04073003
    By RedlinePerformance in forum Custom Operating Systems
    Last Post: November 4th, 2016, 07:01 AM
  3. Flex fuel DBC OS
    By turbo_bu in forum Gen III V8 Specific
    Last Post: March 24th, 2015, 10:44 AM
  4. Looking for a 3.5L or 3.9L Flex Fuel tune
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2009, 01:04 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
Tags for this Thread
