Results 1 to 5 of 5
Thread: Bricked P59 tune
    Jun 2013
    Default Bricked P59 tune
    I've been tuning a swap with a P59/LQ9/4L80E. Everything was going well until yesterday when a cal flash bricked the PCM. I couldn't identify why this happened so I tried another PCM and it bricked that one too. I can't figure out what's going on. Has this happened to anyone else? Not that it matters but the guy that owns the truck is from AUS.
    Here's a list of differences between the last file that ran fine and the one that bricks pcms.
    Comparison summary: 12:48:33 pm, Friday Jul 31, 2020
    Calibration comparison between COS base_0011.ctz and COS base_0012.ctz.
    *Values that differ by more than 0.000100% are considered different.
    04073003 "Operating System" N/A "Identical."
    12587698 "Engine Calibration" N/A "Checksums are different, CAL: 44D6<-> ALT: 8F7D."
    12586212 "Engine Diagnostics" N/A "Identical."
    12578773 "Transmission Calibration" N/A "Identical."
    12578790 "Transmission Diagnostics" N/A "Identical."
    12578800 "Fuel System" N/A "Identical."
    12585938 "System" N/A "Identical."
    12578995 "Speedometer" N/A "Checksums are different, CAL: 018D<-> ALT: 6AF3."
    B0101 "Main VE Table" -5.035156 "Different from cell: 0,0 to cell: 18,15 inclusive."
    B0107 "Max Speed for Idle Mode" -0.485244 "CAL: 2 <-> ALT: 0"
    B0108 "Max Throttle for Idle Mode" -20.000000 "CAL: 20.0 <-> ALT: 0.0"
    B4603 "Desired Idle Speeds" 1.762417 "Different from cell: 0,0 to cell: 3,15 inclusive."
    B4338 "Engine Speed Compensation" -12.750439 "Different from cell: 1,1 to cell: 1,11 inclusive."
    B4307 "Desired Airflow" 7.600519 "Different from cell: 0,0 to cell: 1,15 inclusive."
    B4308 "Airflow Parked" -3.578241 "Different from row 4 to row 9 inclusive."
    B4522 "Stall Saver RPM" 3.320363 "Different from cell: 0,0 to cell: 1,11 inclusive."
    B5402 "Tacho Pullup Enable" N/A "CAL: Yes <-> ALT: No"
    H0105 "PCM Primary Pulses per Mile Output Rate" -1.176489 "CAL: 4000 <-> ALT: 1000"
    H0106 "PCM Secondary Pulses per Mile Output Rate" -40.156865 "CAL: 128000 <-> ALT: 25602"
    You should be able to reset the PCMs, either via reflashing again with a known, good tune with EFILive or reset via the boot pin (google) then flash with EFILive. I'd change B5402, H0105, and H0106 back, I think there's an issue with the PCM when these are adjusted and/or set too low.
    Jun 2013
    Thanks for the tips. I'll have to use the boot pin because neither PCM even shows up when you try to flash them or do anything else. Thanks again, I appreciate it.
    Jun 2013
    It worked. Thanks a bunch.
    Quote Originally Posted by greasess View Post
    Glad to hear you're back up and running!
  1. P59 COS3 04073003 flex fuel issues
    By dmaxguy2008 in forum Custom Operating Systems
    Last Post: February 26th, 2022, 12:21 PM
  2. P59 PCM and PWM fan Control
    By route in forum Gen III V8 Specific
    Last Post: July 18th, 2020, 06:45 AM
  3. P59 Flex Fuel OS with DBW
    By LabZ in forum Gen III V8 Specific
    Last Post: January 29th, 2019, 04:36 PM
  4. Locked P59 PCM
    By derkscustomcars in forum Gen III V8 Specific
    Last Post: January 30th, 2017, 09:04 AM
  5. Warren P59 style PCM with CAN (aka GMLAN)
    By PSS in forum Conversions / Aftermarket Parts
    Last Post: May 31st, 2015, 12:15 PM
