Results 1 to 5 of 5
Thread: PFN LIST ERROR V7.5 SCAN TOOL - help !
    Aug 2009
    Default PFN LIST ERROR V7.5 SCAN TOOL - help !
    Hey guys
    Been having a few issues of late with the v7.5 scan tool showing delayed data , you can datalog a car then switch the ignition off and the data will still keep recording for sometimes up to 1 minute after key off .
    I have this on 2 different laptops.
    The latest issue, I will be data logging and suddenly the p.c will freeze , and I will get a blue screen with "PFN LIST ERROR" - again , this happens on 2 different laptops with 2 different efilive V2's
    Any clues ? memory management ?
    8gb ram on both of these on Win 10 64
    In the scatool, go Help->About and post here the build version.
    The V7 scan tool is single-threaded which means the data logging and the screen update/refresh is done in the same thread on a single core. That can cause the thread to start lagging if it has to draw too many updates. You can reduce the amount of screen update/refreshes by forcing the V7 software to only update the display every "N" frames of data logged. Updating the screen every 4 frames is usually a good compromise, like this:
    Note: The V78 scan tool is multi-threaded and does not suffer from this type of lagging.
    Aug 2009
    Hey Joe
    Did it on V7.5.28 and getting the same problem on V7.5.30
    Blacky
    Thanks Blacky , totally understand that V8 is the next step forward but I have used V7.5 for 10 yrs with no issues whatsoever, now this.
    I asked about this lag once before and had no real improvement even after turning down the update rate.
    It seems to only do it on E38 ecu , E40, LS1 and E67 is seemingly not affected.
    never really got the PFN error before until now either
    I have seen this on my old laptop.
    It turned out to be cpu power/thermal mgmt as the cpu clock being wound back. Was a pain in the ass as it would do it when i had the external battery pack plugged in.
    Easy thing to check, download cpuid & see what the clock speed & multiplier are at when your on mains vs battery.
    I'm currently using a laptop as old as my last one, as i get them from the throw out pile at work. lol. pulled my hard drive out and whack it in this one and away i go.
    the last one was pulling cpu speed down to like 800mhz when on battery.
  1. Scan Tool Error
    By gpr in forum FlashScan V2
    Last Post: April 9th, 2013, 09:26 PM
  2. Scan Tool Error
    By gpr in forum Gen III V8 Specific
    Last Post: January 20th, 2013, 10:38 AM
  3. V7.5 Scan tool error
    By jay p in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 8th, 2012, 06:19 AM
  4. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
  5. getting an error trying to read bbl on scan tool
    By Aint Skeered in forum FlashScan V2 BB Logging
    Last Post: June 4th, 2008, 07:13 AM
