Results 1 to 5 of 5
Thread: Aldl help
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Default Aldl help
    I am in the process of installing a 411/fuel injection system in a 1983 ElCamino, and have ran into a small issue. my ALDL connector has a DK GRN and a TAN wire that I can't find the other end. I also have a couple of other ALDL connectors that have even more wires. Any help or direction would be appreciated.
    Aug 2016
    Do you have the factory wiring diagram? I have a 1984 El Camino and can take a look in my service manual if that would help.
    Sent from my Pixel 3 using Tapatalk
    Jun 2010
    My bad! I should explain better. I am installing a 411 on this system, and have a large selection of ALDL ports. I think the one that I am looking at using is out of a 1999 or 2001 Silverado. It has 3 wires that i cant run down
    Dec 2016
    Hope this helps, LS1A,B uses pin 2 and ground for comm.
    Jun 2010
    Cool deal. Thank you for that.
  1. V2 and ALDL
    By limited cv8r in forum FlashScan V2
    Last Post: March 29th, 2014, 05:16 PM
  2. Aldl connection to V4
    By Pravx ii s in forum EFILive V4
    Last Post: August 5th, 2011, 02:56 AM
  3. V4 ALDL Dashboard
    By willy jordison in forum EFILive V4
    Last Post: March 25th, 2011, 12:51 PM
  4. ALDL Integration
    By limited cv8r in forum General
    Last Post: June 13th, 2010, 07:50 AM
  5. ALDL help/guru's
    By limited cv8r in forum EFILive V4
    Last Post: August 15th, 2007, 01:29 PM
