Results 1 to 2 of 2
Thread: Park netural switch/ gear select switch help
    May 2019
    Default Park netural switch/ gear select switch help
    As stated before, i am building an older car and am in the process of putting in a 411. I am also rereading the Scan Tool and Tunning Tool manuals.........again! To refresh my old noodle on the systems.
    Now the latest problem, I read that we can tell the ECU to use the old cars neutral safety switch (1 wire) or the LS series gear position setup. I did a quick scan of the manual but cant find it again? Could someone please point me in the right direction of that information? Or maybe the parameter number in EFILive? I am having a dificult time finding information on the LS1 gear select/ neutral safety switches.
    Thank you
  1. Replies: 9
    Last Post: September 22nd, 2016, 09:45 AM
  2. 4l60e gear select display
    By greasess in forum Gen III V8 Specific
    Last Post: July 8th, 2015, 12:45 AM
  3. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
  4. Conquering Park/Neutral Signal and Gear Selector Switch (PNP)
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: May 29th, 2009, 11:53 PM
  5. Car is too rich at idle in park / perfect in gear
    By exploder in forum Gen III V8 Specific
    Last Post: December 3rd, 2008, 12:59 AM
