Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: using EFILive like HPTuners
  1. #31
    Aug 2016
    You're making headway, keep it up. If it's your first time working with EFI it's a steep learning curve, keep working at it!
    Your log has very few PIDs, all of them except your long term fuel trim have data which is a step in the right direction. Can you post your most recent tune file? Your tune acts like an input, and a log acts like an output. Looking at your input and output helps determine what needs to change or stay the same with your input.
    Your log is extremely short, it looks like you turned your car on, gave it some gas, and got a 46 second log. Good start, generally when you log you want to try getting a lot of data, 20+ minutes if possible. Since you're still getting the hang of things, these short logs to verify your PIDs are correct are good. Try adding some more PIDs and getting another log, where you see data for each PID after stopping and saving your log. PIDs that reference short term and long term fuel trims will help, also knock retard and E38.APCYL_DMA are helpful. Because you have an E38 ECM, you can choose "E38 ECM" from the drop down menu on the PIDs tab and filter PIDs that SHOULD work with your car. Note SHOULD because each computer's operating system is different.
    For the calc_pids.txt file, I'll attach mine for reference. It has A LOT more PIDs than you need, but hopefully you can look at it as a reference and see how the nomenclature works and what it looks like to make your own PIDs. Only use it for reference, you don't want extra PIDs clogging things up and adding complexity where it isn't needed.
    calc_pids.txt
  2. #32
    Feb 2019
    Need some understanding config layout/def...I'm use to something different.
    I'm guessing # is a comment
    Which language is the aimed for?
    What about a paper on writing a config file for this environment?
    LS3 Manual 6 spd E38 os:12633056
    Texas Speed 1 7/8" headers w/3" exhaust
    Texas Speed cam 229/236 .629/.615 112 LSA
    Hi-Ram intake stock injectors 90mmTB
  3. #33
    Feb 2019
    Default E38 OLSD tune issues
    Hey, I got my support answers:
    1. needed to change properties>connection> cable to V2.5
    2. I had originally had the Dakota Digital Bim connected to OBD at the pin but changed it later because I forgot a dyno tuner said DD Bim could not share can connection. I had changed the connection to be at the can connection (split connector). Thats why all the #31 errors.
    I am attaching my latest tune and short log from Scan7.5 and one from V8. Still not driving it because the fans aren't working (relays wired wrong by a dip...I've had to rewire this harness so many times) and the engine doesn't sound right(like timing and fuel are off. I used Swingtan's guide for OLSD tune and hope I did not miss something. Hope you can see something.
  4. #34
    Aug 2016
    I got busy getting my supercharger buttoned up. My wife and I are leaving with the car tomorrow for a long weekend trip. I had a chance to review your tune really quick.
    Most of my time spent tuning is with the LS1B controller, but I'm starting to get into the E38. Do you have a wideband oxygen sensor? If so, is that something that you are able to plug into your Flashscan and include in your log? I flipped through some of your idle airflow tables and they look okay, timing seems okay as well for the portion of the log where it is idling with no pedal input. I referenced this thread with regards to idle airflow: https://forum.efilive.com/showthread...38-idle-tuning
    Also, can you log SAE.FUELSYS? This will tell us if it's running in open loop or closed loop, just a double check.
    Engines run properly when air, fuel, and spark are set properly. If you have a wideband, log that so we can see how your fueling looks. Commanded AFR is good, but it only tells us the input and not the output.
  5. #35
    Have a read thru this to gain some insight: https://forum.efilive.com/showthread...in-single-log)
    Concentrate on the concepts.
    The calc_pids.txt file is it's own language... note the CLC-00-xxx lables match the pid name to the definition of it...
    the 0.5 and 1.5 are the default display range on the scantool, the .4 is the precision of the displayed value on the scantool, factor is its units.
    Code:
    *CLC-00-110
    factor        0.5      1.5       .4  "{GM.EQIVRATIO}*{EXT.WO2LAM1}"
    Code:
    CALC.WO2BEN       F110   CLC-00-110   factor           Tuning           "BEN from WB"
    Remind us which wideband and how is it connected...?
  6. #36
    Feb 2019
    Quote Originally Posted by pinstripebob View Post
    Thanks, I'll give that a try
  7. #37
    Feb 2019
    I have the Innovate DLG-1/LC-2 wideband setup and working. Just don't have it connected to Flashscan. I have been trying to find a thread about connecting to Flashscan without a lot of success.
    Thanks for the calc_pid explanation. I will have to wait ot mess that up when I am more comfortable with scan/tune.
  8. #38
    Aug 2016
    You need a null modem adapter, then plug it into the serial input of your Flaahscan. Log the LC1 external wideband PIDs.
    Sent from my Pixel 3 using Tapatalk
  9. #39
    Feb 2019
    Where do I get null modem adapter? Does it plug into the 5v or 12v...guess I need to get one then its obvious.
  10. #40
    Aug 2016
    Amazon or any local electronics store should have them. You can see the one I use in the link below:
    https://www.amazon.com/female-slimli...tronics&sr=1-3
    I misspoke earlier, when you do plug in your serial output of your LC2 to your Flashscan, connect them with the null modem adapter. Then choose the following PIDs:
    - EXT.WO2AFR1
    - EXT.WO2EQR1
    - EXT.WO2LAM1
    This will get you measured AFR, EQ ratio, and lambda from your wideband in your log.
  1. using EFILive like HPTuners
    By 5557nut in forum FlashScan V2
    Last Post: September 3rd, 2020, 05:01 AM
  2. efilive or hptuners?
    By dian in forum Gen III V8 Specific
    Last Post: December 10th, 2014, 02:25 AM
  3. Replies: 8
    Last Post: June 10th, 2013, 07:57 PM
  4. efilive v2 vs hptuners
    By mellor in forum FlashScan V2
    Last Post: November 8th, 2010, 09:46 AM
  5. Flashscan vs HPTuners? Upgrade from EFILive
    By Iv_z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2004, 11:29 PM
