Results 1 to 4 of 4
Thread: ECM Question
    Sep 2020
    Default ECM Question
    Okay i have a 2018 Ram 2500 with a 68RFE, my ECM is a CM2350B with E/C code D090066.04. When looking at the base tune library under the 2018 tab the ECM is a CM2350F with the same E/C code as mine, there is no CM2350B under the 2018 tab. The reason i am looking is that my remote start is not function it goes through the motions and the dash acts like the truck has started and everything but the truck has not started. My truck was tuned with EFI and at first my Uconnect heat and vented seats did not work but my remote start did. Had the tuner revise my tunes and the Uconnect functions work now but my remote start does not. My question here is can i use the CM2350F file as a base tune file on my CM2350B ECM?
    Yes you can, if the E/C code matches it is fine. The B & F must have been some internal changes to the ECM but they seem happy enough to share the same tunes.
    Sep 2020
    So if we build a new file with the matching E/C i will more than likely get all my functions back? I seem to always be the lucky one that gets something made between years or updates, lol.
    Yes more than likely everything will start working again.
  1. Read From ECM Question
    By elctlary in forum Cummins 6.7L
    Last Post: October 30th, 2019, 08:59 AM
  2. Flash new ECM question
    By rrmccabe in forum Gen IV V8 Specific
    Last Post: August 4th, 2016, 01:20 AM
  3. lml ecm question
    By akaponch in forum Duramax 2011+ LML / LGH
    Last Post: December 13th, 2014, 09:27 AM
  4. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  5. Question about locked ECM...
    By LBZoom in forum General (Diesel)
    Last Post: February 3rd, 2011, 06:17 AM
