Results 1 to 7 of 7
Thread: September 2020, Beta 51 release 2
    Default September 2020, Beta 51 release 2
    We strongly recommend that you do not install the beta software over the top of your production systems. It is possible that the beta test software may fail and your production system may not be recoverable. lf you conduct a tuning business, please take the necessary precautions to protect your business. EFILive recommends beta testers use a separate FlashScan V3/V2 device (when installing the latest beta firmware) and only install the EFILive beta test software on a separate PC, laptop or virtual machine.
    This beta update contains a new CSP switchable tune operating system for CMF controllers. It is an "early access" feature that is not intended for production use just yet. EFILive is looking for feedback on the performance of the CMF CSP OS. Please do not install the CMF CSP OS on remote vehicles. Only install it on vehicles in your workshop that you can recover easily if the CSP5 OS causes problems.
    For users dealing with the V3 AutoCal products you must use this release and ensure that all devices have the firmware updated to the version in this release prior to being used on vehicles.
    Changes to V8 software
    • Various Cax8 updates.
    • Updated EFILive_CmdLine.exe to support V3 devices.
    • Cax8 provider unique IDs are now displayed correctly in parameter lists.
    • Added full editing support for LS1, E37, E38, E67, E54, E60, E35 and CM2350A.
      Please double check any calibrations that you view/use in the V8 editor to ensure they are identical to the equivalent calibrations as displayed in the V7 editor.
    Changes to V2 firmware (V2.07.164)
    • None.
    Changes to V3 firmware (V3.00.051)
    • Added option to test for bus silence on CAN J1979 and VPW networks.
    • Added power-up options.
    • Fixed VIN license validation that was failing for VIN licenses that had been transferred from a V2 device.
    Full Release Notes:
    Version Numbers:
    • EFILive V7 software: V7.5.31 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.1 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.051 (Sep 14, 2020).
    • FlashScan/AutoCal V2 Firmware: V2.07.164 (Jul 30, 2020).
    Download here:
    Known Issues for Beta 51(1):
    Issue #1:
    When converting V7 *.cax files to V8 *.cax8 files using the [F8: Tools] -> [F6: Bulk Files] -> [Convert User Calibration files] option, literal labels defined in the V7 cax files are not being converted correctly to literal labels in the V8 *.cax8 files.
    And, even when they are manually corrected, the V8 software is still not interpreting the literal labels in V8 *.Cax8 files correctly.
    Workaround:
    None - update to Beta 51(2)
    Regards,
    The EFILive Team
    Oct 2011
    Im still having issues with $0503 errors on the AC3 devices with the newest update. Is there anything that I can try other then reinstalling the software and updating the firmware? It doesnt seem to be a resolution to the error code so far on 3 separate devices.
    Nov 2005
    Post #1 was updated to beta 51(2). Can you please confirm you have that installation, not the earlier 51(1).
    After updating, please ensure your firmware and configuration files are updated.
    If you are still having $0503 issues after confirming all of those, please raise a ticket on our service desk and upload your trace files. At this stage, wev'e had a number of reports that the issue from the earlier beta that resulted in $0503 was resolved with this release.
    Cindy
    Quote Originally Posted by motorhead View Post
    Can you copy all the files (*.obj etc) from the V3 device's \EFILive\Config folder to a new folder on your PC, then zip up that new folder and send it to me directly at paul@efilive.com
    Nov 2009
    I'm IN LOVE with v8 editor!!!!!!!!!!!!!!
    -Kory
    http://www.PPEI.com/
    May 2014
    Is there a better place to provide V8 editor feedback? Just minor stuff, don't want to clutter it up here and doesn't really pertain to the functionality of getting the next stable release out.
    Quote Originally Posted by aaronc7 View Post
    I created a new forum to discuss the V8 editor.
    https://forum.efilive.com/forumdispl...V8-Tune-Editor
  1. September 2020, Beta 50 release 1
    Last Post: September 14th, 2020, 09:38 AM
  2. June 2020, Beta Release - Release 4
    By GMPX in forum Software Updates and Installation Help
    Last Post: August 15th, 2020, 01:51 PM
  3. June 2020, Beta Release - Release 3
    Last Post: June 25th, 2020, 06:15 PM
  4. June 2020, Beta Release
    Last Post: June 19th, 2020, 02:00 PM
  5. June 2020, Beta Release - Release 2
    Last Post: June 19th, 2020, 01:56 PM
