Results 1 to 5 of 5
Thread: Setting pu for speed density tuning
    May 2019
    Default Setting pu for speed density tuning
    Hi again, trying to get the AUTO VE setup so that I can at the least get this thing close enough to drive to the dyno for further tuning. but I have ran into a snag, I cannot find (CALC.EQBEN_LS1). I have gone through the PID list every way I can think of but no joy. I'm sure it is a rename issue any help would be greatly appreciated.
    I am going Speed Density with this, MAF is already gone, IAT is in the intake stream.
    That's a custom BEN you either have to create yourself or download from one of the tutorial threads. It is not in the EFILive software by default.
    Which PCM/ECM (I take it it is LS1B)...?
    Are you obtaining the wideband lambda/EQR/AFR signal from analog voltage or from serial comms...?
    Take a look in the calc_pid.txt file under "1. Setup Calculated PIDS" in this post: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    May 2019
    Yes 411, LC1 serial O2, and are you wanting me to copy the pid txt file over to my EFILive folder? Also some of the Auto VE gets confusing, ill reread it and post my confusion later, still installing the system right now
    May 2019
    well don't I have egg on my face!!! the top of page 8.
  1. Questions with setting up speed density for my elcamino
    By Tinbender59 in forum Gen III V8 Specific
    Last Post: May 27th, 2020, 07:20 PM
  2. lm7 speed density tuning
    By 2003gmc1500 in forum Gen III V8 Specific
    Last Post: February 7th, 2017, 02:27 PM
  3. Speed Density Tuning, Trans now shifting harsh!
    By hotrod in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 21st, 2014, 11:29 AM
  4. Tuning LS1 Superchared 02 TA with speed density and o2
    By RamAir in forum Gen III V8 Specific
    Last Post: October 30th, 2012, 01:34 PM
  5. Tuning Speed Density with Auto VE
    By supercharged88 in forum Gen III V8 Specific
    Last Post: September 9th, 2012, 06:14 AM
