Results 1 to 3 of 3
Thread: Bench harness pinout.
    Jan 2011
    Default Bench harness pinout.
    Does anyone have the pinout for a bench harness?
    And can anyone confirm that the black connector is the same as an e38 black connector?
    Customer is sending up his ecm and I would like to build the harness before.
    Jan 2011
    I found the ecm pinout, The 'bench force' harness just uses 1 connector, C1 Black, There is B+, a few ign + but no grounds in there, Do they use the 'low refs' as ground?
    Jan 2011
    Ill check the grounds and post back here.
  1. CM2200 bench harness pinout
    By DURAtotheMAX in forum Cummins 6.7L
    Last Post: May 6th, 2022, 02:21 PM
  2. cm2350b pinout on bench
    By BYTES in forum Cummins 6.7L
    Last Post: August 14th, 2020, 06:58 AM
  3. E84 Bench Pinout
    By SkyMadness in forum E78, E83, E84 PFI ECM's
    Last Post: December 19th, 2019, 03:32 PM
  4. GM BCM bench wiring pinout
    By 1906 in forum Petrol / Gas
    Last Post: February 21st, 2017, 08:56 AM
  5. Cummins Bench Harness pinout (pictures)
    By vortecfcar in forum Cummins 5.9L
    Last Post: September 2nd, 2012, 05:57 AM
