Results 1 to 8 of 8
Thread: CM2350 Modes
    Aug 2019
    Default CM2350 Modes
    I was wondering why EFI Live doesn't give you the ability to adjust modes 1-5 in each tune file? You are only able to adjust Base, Mode 1, and Mode 2. To really fine tune the truck and make it is working in all modes you would need modes 1-5. Is there a reason why this isn't done? Thank you
    Actually depending on the OS you can tune Base + Modes 1 through to 13 in some cases, not sure what you mean by just having Base, 1 & 2.
    Oct 2012
    The OP is referring to a CSP4 file. At least in the 13 and newer trucks, each CSP "tune" has Base, Mode 1 and Mode 2 with the rest of the modes outside of the CSP area.
    Aug 2019
    That is exactly what I was saying. Anyway to have them all inside the 4 CSP files?
    Well actually you didn't say anything about CSP in your original post
    Anyway, this is not possible due to the lack of free flash memory in the ECM, I did some quick maths and if we were to include all modes in the switching sets (based on the maps we have) you couldn't even get two tunes in some of the OS's out there.
    Unfortunately it is a compromise in that we can only work with what Cummins have left available to us.
    Aug 2019
    Sorry for leaving that out. I appreciate your feedback, and understand why it is not possible. Thank you for all you guys do.
    Aug 2019
    I just read my reply from earlier and I came off like an *ss. Sorry about that.
    No worries, no offence was taken.
  1. CM2350 on the Dyno Keeps coming up with SCR1
    By Twistedshafts in forum Cummins 6.7L
    Last Post: 5 Days Ago, 11:24 AM
  2. Cummins Stock file 2013-UP CM2350
    By GM-Josh in forum Cummins 6.7L
    Last Post: February 12th, 2018, 08:21 AM
  3. CM2350 Bench Connection
    By DemonDMAX in forum Cummins 6.7L
    Last Post: September 25th, 2017, 11:01 AM
  4. Different 'modes'
    By RADustin in forum Duramax 2011+ LML / LGH
    Last Post: April 11th, 2017, 09:47 AM
