Results 1 to 2 of 2
Thread: DSP5 question
    Sep 2020
    Default DSP5 question
    Hello all,
    My dsp5 switch broke. Where I installed it, it's loose now and the threads on the switch are stripped out so I can't tighten it. The whole assembly turns when I try to select tunes. Also the washer that prevents more than 5 turns broke, so the switch now has more than 5 positions.
    Can I buy any dsp5 switch and splice it into the old switches wires? I'm not going to take the pins out of the ecm connector and re-install the pins from the new switch... I'm just going to cut the wires near the switch and solder the new wires to the wires that go to the ecm.
    I guess I'm asking if there is a difference in the switches, both from tuners suppliers and engine types (lmm, lly, etc...). I know the switch varies voltage and that's how the ecm knows what tune is selected... are all switches set to the same "voltage steps" or is it tuner specific?
    Thank You
    P.S. my truck is an 08 silverado 2500HD (LMM)
    Oct 2012
    Yes, you can splice a new switch into an existing. Disconnect the batteries, the the wires from the current switch one at a time, then splice the new wires/ switch in.
    Buy a switch specific to the LMM/ LBZ.
  1. DSP5 - question
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 28th, 2011, 05:33 AM
  2. DSP5 Question
    By puller705 in forum Diesel
    Last Post: October 1st, 2011, 09:56 AM
  3. DSP5 question
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 13th, 2011, 10:10 AM
  4. DSP5 Output Question
    By JrTuner in forum Duramax LB7
    Last Post: August 25th, 2010, 12:25 PM
  5. dsp5 question
    By dirtymaxx03 in forum Duramax LB7
    Last Post: December 21st, 2009, 05:23 AM
