Results 1 to 1 of 1
Thread: Drag and Drop
    Default Drag and Drop
    Drag a scan file or a tune file from Windows Explorer to EFILive V8's main window to open that file in a new window.
    Drag a scan file or a tune file from Windows Explorer to a scan or tune window to open that file in that window. If the file being dropped is able to be compared with the existing file in the window you will be asked if you want to compare the two files or simply open the new file.
    You can select two files in the main window's list of previously open tune files, then right click on one of them and select "Compare Items". The file that you right click on becomes the base file, the other file becomes the alternate file.
  1. Drag and Drop file issues
    By tanman in forum AutoCal
    Last Post: June 7th, 2019, 05:53 AM
  2. Wyotech's Drag Truck Build Up HELP
    By WyotechPA in forum Duramax LB7
    Last Post: May 5th, 2009, 06:02 PM
  3. Drag Racing logs
    By oztracktuning in forum Gen III V8 Specific
    Last Post: November 7th, 2007, 11:45 PM
  4. a question for you drag racers
    By tgeers in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2006, 02:13 PM
  5. First Drag Race Log
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2006, 08:17 PM
