Results 1 to 5 of 5
Thread: Ls1 pcm
    Mar 2007
    Default Ls1 pcm
    I use allot of 411 (blue/red connector) as we almost always use cable throttle. I know some use the PCM with blue/green connectors with cable throttle. Is there particular blue/green ones that can and cannot be used with cable throttle?
    Mike
    To be used with DBW/ETC throttle, the PCM board must have the transistor/IC drivers, otherwise it can only do cable throttle.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    I think the question was if there were DBW 0411's that could or could not be used for DBC... I'd assume (could be wrong tho) that if its hardware capable of running DBW, it could be tuned to run DBC.
    Sent from my HTC U11 using Tapatalk
    Mar 2007
    Perfect thanks
  1. LS1 PCM's
    By GMPX in forum Please Read First
    Last Post: November 29th, 2011, 03:08 PM
  2. 98 LS1 with 99 - 02 Pcm
    By madprof01 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2006, 02:25 AM
  3. 98 LS1 PCM's
    By Homeslice in forum General (Petrol, Gas, Ethanol)
    Last Post: May 4th, 2005, 06:47 AM
