Results 1 to 5 of 5
Thread: Valet option
    May 2019
    Default Valet option
    sorry for all the questions, just trying to get it all correct.
    my silly question for today is, can I use Valet on the stock tune or am I forced to use a COS? my rig is a 1985 Elcamino, kind of a high theft rig, a will also be installing some sort of tracker in the car. but would like to incorporate Valet.
    The ability to add a Valet switch to the LS1B PCM is only enabled with an EFILive Custom OS, so yes, have to use a COS. GM's factory OS does not have this code in it.
    May 2019
    Ok! thank you! for the responce, anything / tricks that i should know before i start this process?
    You'll need to make sure the base OS you use is setup for your wiring/vehicle config. The COS upgrade doc for the LS1 has a lot more information and detailed step-by-step how-to, including what to use for a switch.
    May 2019
    Cool. Thanks
  1. Valet tune?
    By Rich Z in forum Gen III V8 Specific
    Last Post: November 1st, 2014, 04:13 PM
  2. Valet Problems
    By dirt_track_racer_81 in forum Custom Operating Systems
    Last Post: April 11th, 2007, 02:37 PM
