Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: P59 COS3 04073003 flex fuel issues
    Mar 2009
    Default P59 COS3 04073003 flex fuel issues
    So i did some searching here and on hptuners and sloppywiki. I am trying to get my content sensor up and going. First i flashed a custom os 040730003 in then flashed a 04 tahoe with flex enabled cal. Read it out. Did segment swaps from the old os that had flex turned off. Full flashed that in. Pin A is flex input pin 59 blue connector Pin B is ground. Pin C is 12v switched power. The sensor is a continential style from ecumaster.com came with a nice 6ft pigtail. Turn the key on and percentage is stuck at 0% i have a 26 gallon tank has 22gal of 91 and 4gal of e85 just to test. Figured id start with a small amount of e85 just in case near as i can tell assuming im getting E70 (.70x4=2.8gallons of pure ethanol) so (2.8/26=10.7%) so i should be seeing at least 10% on the scanner correct? Any help would be great!
    May 2014
    Should be Blue Pin 56 no? Also post tune file
    Mar 2009
    sorry yes it is on pin 56
    Mar 2009
    this file is current
    May 2014
    Flex fuel isn't fully enabled in the tune, probably got dorked up when you did the segment swap back to old OS that it wasn't enabled on. Best thing you can do is install a cax that maps those hidden FF tables so you actually know what's going on with the calibration.
    See link below. Rename one of the cax files to 040730003.cax and compare to one of those corvette files or 04 tahoe file that is -7603 OS and check out all the FF related tables to make sure you have sane values. I saw a bunch of the tables in the "flex fuel" folder need values and don't forget about the spark blend table(s) as well. There's also quite a few cranking fuel tables.
    Another random note, right after a flash I think it's pretty normal for ethanol content to read 0, until you start it up and then the value will slowly creep up to actual ethanol content. For example just today, I flashed my car, started it up...content was 0, and then crept up to 12.2 percent in about 30 seconds to a minute.
    https://forum.efilive.com/showthread...Corvette-Files
    Mar 2009
    Okay i will try that. I ran the car for quite a while and content never increased.
    Mar 2009
    please forgive my ignorance but i have no idea how to create or make a .cax file thought i did but.... i guess not tried looking on the forum with not much luck seems as tho everyone that asks is one step ahead.
    May 2014
    Drop the cax file in C:\Program Files (x86)\EFILive\V7.5\Calibrations
    Then compare to the Tahoe FF enabled tune file to see what FF settings needs adjusted and a good starting value etc.
    See attached zip below
    Mar 2009
    thank you so much ill see if i can fumble thru this!
    Mar 2009
    im sorry ive never done this before so i dropped the .cax in the file you stated now how do i compare to the stock tahoe file? which program? like i said i am sorry for being ignorant but ive just never had to mess with this stuff before im trying to learn. like ive never messed with any of this before today. all ive ever done is what the base efilive software allows.
  1. P59 Flex Fuel OS with DBW
    By LabZ in forum Gen III V8 Specific
    Last Post: January 29th, 2019, 04:36 PM
  2. Truck won't start with cos3. Runs fine with regular file. 12587603/04073003
    By RedlinePerformance in forum Custom Operating Systems
    Last Post: November 4th, 2016, 07:01 AM
  3. Flex fuel DBC OS
    By turbo_bu in forum Gen III V8 Specific
    Last Post: March 24th, 2015, 10:44 AM
  4. Looking for a 3.5L or 3.9L Flex Fuel tune
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2009, 01:04 PM
  5. Converting a NON-Flex fuel vehicle to Flex fuel??
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 1st, 2008, 06:15 AM
Tags for this Thread
