Results 1 to 8 of 8
Thread: Stock 2002 M6 file and injector help
    Oct 2020
    Default Stock 2002 M6 file and injector help
    I bought a used 2000 M6 car that the ECM is just a mess. 2 Bar OS everything is bad for a HCI car. I have a spare 411 ECM but it has an A4 file in it.
    I'm looking for a bone stock 2002 Camaro M6 file I can just dump in this and start from scratch with, I've looked all over the net and everything seems to be so old its gone.
    I'd also like to ask about injectors. It has 60lb deka injector 1017961
    https://www.highflowfuel.com/i-23906...-injector.html
    If my math is right they are 82lbs an hour at 58PSI. Do I multiply the IFR table by 2.9? I've never had to scale this big going from 28 to 36 is no big deal. I just need the car to ran good enough to turn everything else. Eventually it will be FI so I'd like to just use them.
    Thank you for any and all help.
    here you go
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Oct 2020
    Awesome TY
    Trying to find the injector data. I've only found it for the 80lb injectors.
    Dec 2016
    Quote Originally Posted by rfborden View Post
    Sorry, your math is wrong. Here's an online calculator https://www.deatschwerks.com/fuel-ca...ure-calculator
    It will get you in the ballpark even though it isn't 100% accurate. There is much more involved besides correction of the injector constant. The injector offset vs pressure vs voltage is very critical and has to be adjusted with wiring harness issues. Some of these things have to be adjusted with the project. I always start with as correct a value as I can and then adjust accordingly. I have injector test machines and although quite useful to at least make sure things are equal at different PW, the numbers have to be changed in the vehicle. At least it is a starting point.
    Oct 2020
    Thanks for that I didn't realize how far off I was. The more I dig the more I realize that all those other tables need to be adjusted. I have the data sheet is it in there or do I need to do scaling based off of my 28.8 stock injectors that are in my file?
    What would I need to change in the wiring harness? They are currently on the car and it was running.
    Oct 2006
    Do not scale from stock injectors. The correct info is out there you just have to look.
    On the other tunetool site there is a spreadsheet for converting the ford data to GM table format. You will need to transpose the tables to work in Efilive though.
    https://forum.hptuners.com/showthrea...highlight=ford
    The Tremor at AIR
    Oct 2020
    Thank you, I've slowly found most of the data but that link really helped the details.
    Note that the EFILive tunetool has a table transpose tool, look at the last tab.
  1. Need a stock tune file 2001 2002 LQ9 6.0
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: September 11th, 2014, 02:03 PM
  2. Looking for a stock 2002 Suburban Tune file OS 12216125
    By 1fastgto in forum Gen III V8 Specific
    Last Post: August 5th, 2011, 01:47 AM
  3. Looking for stock file for 2002 Escalade
    By JR_VETTE in forum Gen III V8 Specific
    Last Post: June 26th, 2007, 11:54 PM
  4. I need a stock or modified 2002 5.3 silverado tune file
    Last Post: July 24th, 2006, 01:36 PM
  5. Getting a stock 2002 C5 A4 .tun file
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: June 25th, 2005, 12:33 PM
