Results 1 to 4 of 4
Thread: ambient temp. sensor stuck at 32 degrees (freezing) after tune
    Dec 2006
    Default ambient temp. sensor stuck at 32 degrees (freezing) after tune
    On a 2016 Silverado, after reading codes, reading tune, modifying and flashing I now get a warning about ice and 32 degrees readout on IPC
    Is this normal and how to reset?
    '01 Z28 LS1 / T56
    7.59 @ 94.45 (1/8 mile)
    YouTube channel
    '02 C1500 L59 / 4L60E
    8.24 @ 85.08 (1/8 mile)
    www.lsxnos.com
    Dec 2006
    Think I may have found the answer:
    https://ww7.oemdtc.com/2026/diagnost...-chevrolet-gmc
    '01 Z28 LS1 / T56
    YouTube channel
    www.lsxnos.com
    Dec 2016
    I had that happen once with the e92 reprogram. I disconnected the battery and crossed the power and ground to completely drain all the modules. Then everything re-synced and all was fine. Hope yours is that simple.
    Dec 2006
    Thank you and that's worth a try to see if it can speed things up albeit there may be minor other consequences to that procedure (radio stations, time, fuel trims, codes) but maybe not.
    '01 Z28 LS1 / T56
    YouTube channel
    www.lsxnos.com
  1. Read Evaporator Temp Sensor?
    By Trumpetrhapsody in forum Cummins 5.9L
    Last Post: May 11th, 2016, 11:40 AM
  2. Replies: 3
    Last Post: January 19th, 2016, 09:08 AM
  3. Replies: 4
    Last Post: December 11th, 2015, 09:24 AM
  4. Engine Coolant Temp Sensor
    By auspeed in forum Gen III V8 Specific
    Last Post: June 29th, 2013, 12:09 PM
  5. Fuel temp sensor table
    By Duramax01 in forum Duramax LB7
    Last Post: April 8th, 2013, 12:57 PM
